Spark Plug Change - Aluminum Heads
Old Nov 9, 2009 | 12:48 PM
ristpin's Avatar
Default Spark Plug Change - Aluminum Heads
I'm getting ready to change the plugs in my '04 Silverado with a 5.3 eng. What is the best anti-seize to use on the threads as this eng. has aluminum heads? What have you used that works well, or what is NOT recommended? Thanks.
Old Nov 9, 2009 | 2:45 PM
desrtrat's Avatar
any good parts store should sell a small tube of anti seize by Permatex. small tube will last a long time..
edit.. also pick up a small tube of dielectric grease and put a small amount in the plug boots, and roll the boots between your fingers to spread it evenly in the boot, and install..will help a lot when you have to remove the wires again.. ALSO put on your coil boots also..
good luck
mamulan
Aug 20, 2014 8:39 AM
TPM
May 14, 2013 5:58 PM
sngreen
Jun 4, 2007 7:48 AM
girraffe111
Apr 27, 2005 10:17 PM
