Speakers
Old Jul 15, 2007 | 10:24 AM
Raydah's Avatar
Default Speakers
For my next challenge, my driver side front speaker is blown, I was thinking about replacing myself but after figuring out how to remove the door panel I couldn't figure out how to remove speaker, has anyone accomplished this task or would I be better off seeing a professional. I went to Best Buy and they told me I needed an amp, new receiver the whole ten yards, sheesh I just want a speaker.
Old Jul 19, 2007 | 3:42 PM
redneck 4 life's Avatar
Default RE: Speakers
There is no reason for u to get an amp if ur replacing a stock speaker. the spaeker should be ethier slid in and has clips to hold it in place or there is a couple of bolts in it all u need to do is find the designated size i think it is like a 6x9 or so just go to ur local wal-mart and get a box of two if u replace one u should replace the other it will sound better and get some butt splices, cut the existing wires as close to the old speaker as possible the strip them and splice them and put it in how it came out. i put pioneer speakers in mine and they sound good
~REDNECK 4 LIFE~
Old Jul 19, 2007 | 5:17 PM
ZX1100F1's Avatar
The door speakers in Silverado's have been 6.5" round units for years.
Most of them use a single hex head screw to retain the lower portion of the speaker and a spring clip at the top, once this screw is removed the upper portion is just unsnaps, it is very simple.
Make sure to replace both speakers with a pair of very efficient (co-axial) 4ohm or even one of JBL's new 2ohm speakers and then you should be OK with factory power (unless you're a real head-banger).
Ertsride1
May 9, 2008 1:35 AM
bmac
Nov 12, 2006 12:13 AM
PoWeRs
Colorado
Jul 27, 2006 2:55 AM
