Speedometer jumping problem
Old Feb 16, 2014 | 9:38 AM
aav240sx's Avatar
Exclamation Speedometer jumping problem
Howdy all,
So I have a problem with the speedometer in my '06 silverado w/ the 5.3 v8. With the key turned to accessories or when the truck is started, the speedometer bounces between 0-80 mph erratically while the truck is in park/not moving. I'm trying to pinpoint the reason for this. Things I've tried so far is pulling the DIC fuse, disconnecting the battery to trying to reset it, but the problem still persists. I'm at a loss at where to begin checking for solutions
Leading up to this problem, I installed a double din Kenwood heat unit the other day with the chime retention module, and everything worked fine. I even drove it around and the everything was operating as it should. I didn't find the problem with the bouncing speedometer needle until I routed a power cable from the engine bay to the cabin to hookup my subs/amp. Before I even connected the power cable to the battery, I stuck the key in the ignition to accessories on and found the speedo needle was bouncing around.
I've since pulled the power cable and tried to retrace my process to find the problem, but the problem still persists.
So what could I have jiggled loose, touched, or done to cause my speedometer to start bouncing up and down.
Any help and comments are welcome. Thanks in advance~
**Edit** Been messing around with it, checked various fuses, and disconnected the battery again to try and reset everything. I managed to get the speedometer needle to stop jumping around, but now the needle does not register any speed at all... So now the question is what would make the speedometer stop working? Vehicle speed sensor? Blown fuse/resister/electrical component?
Old Feb 16, 2014 | 10:22 AM
Your problem might be caused by the problem GM had with their stepper motors in the gauges. From 03 to 06 these stepper motors were faulty and would eventually cause problems similar to yours. There was a recall on these. It might be too late for you, but you can check with a dealer if yours was on the recall and if it is still good.
Old Feb 16, 2014 | 10:32 AM
aav240sx's Avatar
Thanks for the reply! Yes, from searching around, I found that many people did have problems with the stepper motors in their clusters. I did find that the needle does move down below zero and then back to zero right when I start it up so I can't imagine that it's completely out...
Any idea on what I could check that may cause the speedometer to not register vehicle speed?
Old Feb 16, 2014 | 1:33 PM
It could be the speed sensor or it could be the stepper motor. If it goes down below zero then I would guess it is the stepper motor. The other 5 stepper motors will also eventually go bad.
Old Feb 24, 2014 | 1:35 PM
aav240sx's Avatar
So... Not sure what the problem is... I ordered and installed a new stepper motor into the speedometer. Same problem persists. Dropping it off at the Chevy dealer tomorrow.
Old Feb 26, 2014 | 10:49 AM
Official GM Rep
aav240sx,
Please keep us posted. If you need assistance while at the dealership, please do not hesitate to reach out.
Erica Tiffany
Chevrolet Customer Care
Old Feb 26, 2014 | 10:55 AM
'03 Heavy Chevy's Avatar
There is still a good chance that your new motor is bad.
Several years ago I had to replace my gauge cluster (I had several gauges that would work / not work sometimes or they would give faulty readings).
Please let us know how your problem is fixed. Thanks!
Old Mar 6, 2014 | 6:59 PM
aav240sx's Avatar
So I ended up not taking it to the dealership because I was told they'd just swap out the cluster for over $500 to start off, and I don't have the funds for that.
What I ended up doing was pulling the cluster and sending it out to a guy out in Minnesota who does cluster repair to have all the motors replaced and updated the VFD and to have it all calibrated. I got it back today and re-installed the cluster to have the speedometer and tripometer still not work...
So any suggestions on what to check out at this point? I feel like it has to be a sensor, or loose wire to a sensor at this point...
chrisbbach
Feb 8, 2009 12:07 PM
NickDawg
Nov 2, 2008 7:54 PM
masportster
Mar 28, 2008 10:49 AM
Tahoeguy2
Dec 10, 2007 1:25 PM
thegrove45
Nov 19, 2007 8:20 AM
