starting issues 97 silverado
Welcome to the forum
Checking fuel pressure is always a good place to start, check the bleed down time as well, it should not be too quick. Pressure should stay for several minutes after the engine is turned off.
There is a check valve in the fuel pump assembly. This is bad that is why your fuel bleeds back into the tank. My truck was doing that and I put an inline check valve in the fuel line and now it starts up on first attempt. You can change them fuel pump also, but is more expensive and more work.
silversilverado
May 5th, 2014 10:23 AM
TheEric
March 15th, 2014 10:55 AM
Samantha Rose Newman
October 16th, 2013 2:57 AM
Chev1500clutch
August 5th, 2011 5:07 PM
