starting issues 97 silverado
Old Dec 28, 2012 | 6:05 PM
johns04's Avatar
Default starting issues 97 silverado
i have a 97 silverado with a vortec 305 and i have to cycle the key to get it started when its cold but once started it will start fine rest of day any ideas
Old Dec 28, 2012 | 7:01 PM
Welcome to the forum
Checking fuel pressure is always a good place to start, check the bleed down time as well, it should not be too quick. Pressure should stay for several minutes after the engine is turned off.
Old Dec 29, 2012 | 7:17 AM
johns04's Avatar
Ok thanks I have heard that I could be the pump or the fuel pressure regulator or maybe the map senserl
Old Dec 29, 2012 | 11:37 AM
There is a check valve in the fuel pump assembly. This is bad that is why your fuel bleeds back into the tank. My truck was doing that and I put an inline check valve in the fuel line and now it starts up on first attempt. You can change them fuel pump also, but is more expensive and more work.
silversilverado
May 5, 2014 10:23 AM
TheEric
Mar 15, 2014 10:55 AM
Samantha Rose Newman
Oct 16, 2013 2:57 AM
Chev1500clutch
Aug 5, 2011 5:07 PM
