starting problem
Old Jul 31, 2006 | 10:49 PM
unrealchevy's Avatar
Default starting problem
hi all just a quick question i have a 2000 silverado and my problem is this when i turn the truck over it doesnt start one first try even on second try sometimes ? it does always start up just takes a few tries any suggestions?
Old Aug 1, 2006 | 4:04 AM
NCHEVYHEVN's Avatar
Default RE: starting problem
I would first start off by checking your fuel pressure at the fuelrail.
Old Aug 1, 2006 | 5:40 PM
thx alot man after i wrote the post i realized someone else had almost same post felt like an ***...lol but i will check that i guess i have to have a book to check that huh
Old Aug 3, 2006 | 11:14 PM
fastfirebird's Avatar
I had the other post on this. Check your pressure regulator on the driverside on the fuel rail. pull the vacume line off of it and check to see if there is fuel there if there is that is the problem. The part cost $80 from Napa and all of 10minutes of your time. hope this helps.
Old Sep 26, 2006 | 4:08 AM
bpear's Avatar
Hi, just found this site, and I'm having a similar problem with my 98 Silverado, 5.7 350 It all of a sudden started to act up, when I go to start the truck. It takes a couple cranks to start, I have found that if I put the key in the run position and listen for the fuel pump to "prime" then the truck starts fine. The truck runs great after it has started and running. When the truck sits for a short period of time it starts fine, but if over night same issue. Do you have any more info on the pressure regulator? does it act lik a check valve? to keep fuel at the throttel body? thanks in advance.
amesblog
Sep 14, 2014 4:31 AM
TG
Aug 16, 2006 4:30 AM
ffarv
Apr 9, 2006 1:52 PM
