Strange Problem Dash Indicators
Old Feb 8, 2015 | 10:28 PM
kit141a's Avatar
Default Strange Problem Dash Indicators
05, 2500,6.0, 85K. Problem that I am having is that since it started getting cold in northern Mn. When first starting the truck in the AM, starts fine, I get the following things happening - tranny temp does not move, fuel gauge not accurate, driver info panel not lite, all warning lights randomly flash (battery.T/C. etc), The battery and oil gauge work fine. After the cab warms up, will still not work. What I have to d o, after driving for 5 min, and cab is warmed up, shut the truck off and restart and all is fine. If truck stays warm all day have no more issues unless I let it set for awhile. The truck runs fine. Somebody mentioned motors but do not understand that Thanks
Old Feb 9, 2015 | 5:34 PM
goyakpacking's Avatar
I had erratic problems with my PU instruments (Silverado 2005)....it also made the speedometer go berserk. My problem was the instrument panel ribbon board, a.k.a Instrument Cluster . It was replaced under some type of warranty. Never had a problem after that.
Could be a crack in the ribbon board that makes an "Open" when cold and contracted. A high resistance open on part of the circuits, a high resistance ground connection that could affect multiple components. Or bad stepper motors? This could change due to temperature differences. Most all the instruments and lights of the dash run off this cluster.
Mine was covered at around 55K miles under some type of service advisory, special policy bulletin, silent recall, extended warranty, or something. What ever they call an unannounced recall. I was told several terms but don't remember now. I just remember it didn't cost me anything. But my speedometer eventually started acting up (in the cold) and triggered me to take it in.
Yours might be covered under the same? See article and others like it http://drspeedometer.com/silverado-i...cluster-recall
Other option if it is a cluster problem: http://www.gmgaugerepair.com
Old Feb 9, 2015 | 9:24 PM
kit141a's Avatar
Default Lights
The thing that throws me is it only happens when it is super cold, Cannot think of anything electrical that controls all this stuff that could be affected by the cols
Old Feb 9, 2015 | 11:18 PM
sledge.impy's Avatar
What did you miss about goyapacking's post?
At any rate, if it's not affecting your driving (stability track warnings/etc), then don't worry about it. Spring around the corner, then summer.
Global Warming will save your vehicle issues.
Old Feb 10, 2015 | 11:27 PM
kit141a's Avatar
never said it was cold related just that it was bad.
Badappleman
Aug 22, 2011 10:49 PM
Gwampa
Oct 13, 2009 8:00 PM
hhpopp
Feb 22, 2008 11:05 PM
old dog
Dec 28, 2007 3:41 PM
Brian02
Jul 18, 2005 11:20 AM
