Stripped sparkplug hole
Old Aug 14, 2012 | 6:31 PM
starvnmarvin's Avatar
Default Stripped sparkplug hole
I have a 1996 chevy shortbed with a 4.3 vortec and I have a sparkplug that keeps backing out because the hole is stripped. Is there a fix with out replacing the head? maybe some kind of sleeve insert modification? If it would mean replacing the head I would rather replace the engine thus it already has 256,xxx miles.
Old Aug 14, 2012 | 6:37 PM
old dog's Avatar
Default strioed hole
give these guy]s a try !
++ TIME-SERT SPARK PLUG THREAD REPAIR KITS ++ spark plug thread repair kits for spark plug problems, thread stripped spark plug repairs in damaged threads in spark plug hole stripped out approved thread repair, aluminum head spark plug repair
Old Aug 14, 2012 | 7:21 PM
spyncycle's Avatar
No matter what you do to fix this, the head has to be removed to do it.
Old Aug 14, 2012 | 9:37 PM
jesse06's Avatar
not sure if a HeliCoil would work in your situation, sounds like the threads are GONE, so you cant use a thread chaser. might have to take the head off to fix
Old Aug 14, 2012 | 10:05 PM
MDTAHOE's Avatar
Professional Mechanic
They sell heli coils for spark plugs. You can do it with the head on. 5.4l Fords blow the spark plugs out all the time. They sell a special insert for those (will not work for your application). We drill and tap the hole with the head on all the time. You must set the engine up so both valves are closed, drill it, tap it then blow the metal out out cylinder with an air compressor.
Old Aug 15, 2012 | 1:38 AM
jesse06's Avatar
so you think the helicoil would work, or you saying it should get the hole bored out and put new threads at the next plug size up?
Old Aug 15, 2012 | 7:18 AM
MDTAHOE's Avatar
Try the heli coil
Nebulation
Feb 1, 2014 6:34 PM
Cretaccir
Jul 7, 2013 6:16 PM
Zombie Toes
Oct 23, 2012 3:35 PM
Morten
Jun 15, 2012 2:34 AM
eudaman
Mar 17, 2007 1:45 AM
