Stuff to make my truck go faster ...suggestions?
i already have a bullydog.....and my afe stage 2 will be coming in the mail today!!! its pretty quick now but want to go faster ....oh and im already investing in a transpack ???anyone no anything else tht would help out
Sell the bully dog to some other kid, don't get the trans pack or whatever.
Order a vette servo from oregonperformancetransmission.com, will increase the shift pressure in 1-2 and 2-3 shifts. Then go to Blackbearperformance.com and email Justin about a custom tune, not a handheld programmer like hypertech, jet, superchip etc. then feel the real difference.
I have the exact same truck as you, did the same mods then went to what I told you to do and will new order a handheld again
to make your truck go faster depends on how much you want to spend
in mt opinion trucks are ment to be trucks not race cars but i have some sugesstions
1. free flowing air intake tube with a good filter
2.long tube headers (not shortys)
3.free flowing true dual exhaust with an x-pipe(no flowmasters)
4. high flow cats or no cats at all
5. change your re gear ratio
6. take off your fan thats on the motor and run an eletric fan
7. a bigger throttle body
this is mostly bolt on stuff but if you wanted to tear into the motor you could
1. cam it
2. bore it out
3. new heads
if you want to go wild and blow some money you could
1. add a supercharger
2.add a turbo
what ever you do and whatr ever mods you do i strongly suggest that you get a custom tune to make everything work right together black bear has an awsome custom tune and most of them places offer free re tunes from what i hear you will be amazed what the tune can do exspecialy when tieing in all the mods together
also remeber that the more hp you go for the more your mpg will drop and the more your foots in it the less mpg as well
1. cam it
2. bore it out
3. new heads
2.add a turbo
An LS1 or LS2, hell, even a ZR1 engine.
Larger throttle bodies
High compression pistons with adjustable cam sprockets
True dial exhaust
Turbocharger
Headers
I can keep going but it gets pretty expensive after this
True dial exhaust
Turbocharger
Headers
im just tryna be the fastest ya know haha so far with this bullydog iv won 5 straight nd havnt lost but i no theres others tht i no if i race i could risk tht undefeated record!!!!,,,,,,,,,,,,,, but not much of this will matter in a month anyway because i will then have a 6inch suspension lift and 38s with 20s sooo thts a huge huge huge huge huge huge SLOW DOWN!! cause right now all i have is 33s with 16s
Cpb200
1. I Already have a CAI - afe stage 2
2. I couldnt find long headers for my truck just shortys JBA to be exact for $388
3.i have straight pipes
4.i still have my cats
5. what would be the best to change em to ?? 4.10? (and i heard thts expensive (labor) im keepin everything under 500 at the most
6.true i heard a fan helps a little bit
7.i heard throttle body spacers are a waste of money by to many people
__________________________________________________ ________________________
Mille Racer 69
1. to expensive for me haha
2.i heard from plenty of people tht throttle body spacers do nothing at all
3.to expensive
4.expensive
5. i cant find long headers for my truck
Country_09
1.which vette servo to get ??? i see lots and i dnt no to much about transmissions
2.tht blackbearperformance thing how much did tht cost you ?
3. I HEARD you can get a vette servo and and a transpak!! is tht true?? heard its great
4. and iss this the right one to get
4L60E 700R4 4L80E 4R100 E4OD 2004R C6 TH350 TH400 Transmission Parts: Corvette Servo kit for the 700-R4, 4L60E, 4L65E Transmissions
Mille Racer 69
3.to expensive
4.expensive
Country_09
Last edited by chesterz71; January 17th, 2012 at 8:33 PM. Reason: needed more info
