is this supposed to be there
There are 10 check ***** total.
3 in the case side (two in 'capsules') and one loose beside the 3-4 accumulator bore. Then, there are also 7 on the valve body side.
Look for the "bathtubs" in the channeling on the valve body.
Allan
Allan
No,
The ball shouldn't be "jammed" or "stuck" into the spacer plate.
You may be able to turn the plate upsidedown on a flat surface and bring it flat again with a hammer.
However, if the hole is enlarged or 'torn', you'd better get a new plate.
Allan
Allan
Mud_Truckin
Jun 4, 2009 1:53 PM
livinloud
Jan 10, 2007 5:13 PM
