is this supposed to be there
Old Jul 21, 2012 | 3:27 PM
isrummell's Avatar
Default is this supposed to be there
is this check ball suppoed to be in the spacer plate, its out of a 4l60e
Old Jul 21, 2012 | 4:15 PM
the iatn site might have alot of folks who could provide answer? that is if the one trans builder on this site doesn't respond...allen?
Old Jul 22, 2012 | 5:57 AM
Allan In NE's Avatar
There are 10 check ***** total.
3 in the case side (two in 'capsules') and one loose beside the 3-4 accumulator bore. Then, there are also 7 on the valve body side.
Look for the "bathtubs" in the channeling on the valve body.
Allan
Old Jul 22, 2012 | 7:03 AM
isrummell's Avatar
so that one isnt supposed to be imbedded into the spacer plate and i new one right
Old Jul 22, 2012 | 9:33 AM
No,
The ball shouldn't be "jammed" or "stuck" into the spacer plate.
You may be able to turn the plate upsidedown on a flat surface and bring it flat again with a hammer.
However, if the hole is enlarged or 'torn', you'd better get a new plate.
Allan
FortBurb
Sep 12, 2011 10:56 AM
sleekpete
Apr 23, 2011 3:10 PM
MNCDurst
Sep 23, 2009 10:49 PM
Mud_Truckin
Jun 4, 2009 1:53 PM
livinloud
Jan 10, 2007 5:13 PM
