Old Aug 10, 2015, 3:27 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Steering & Suspension Guides
Print Wikipost
Suspension Lift Question(s) !!!!!
Old Aug 4, 2010 | 4:55 PM
  #11
jbo9287's Avatar
ahh, I understand now.
Thanks!
Old Aug 4, 2010 | 4:57 PM
  #12
jbo9287's Avatar
any specific brand you would recommend for a suspension kit? I have my body lift set in stone already.
Old Aug 4, 2010 | 9:35 PM
  #13
jbo9287's Avatar
Well, I think I got my plan set in stone now! I think I'll do about a 4" suspension kit WITH a 3" body lift.
Old Aug 6, 2010 | 5:05 PM
  #14
Dopeoperator's Avatar
what suspension kit did you decide to go with?
Old Aug 7, 2010 | 6:30 AM
  #15
jbo9287's Avatar
Part Accessories 3" Body Lift
Old Aug 7, 2010 | 12:49 PM
  #16
hooks55's Avatar
pro-comp sells a 5" leveling kit for chevy not sure if it would be comp. with you c-10 worth looking into though. it worked great on my 01 1500. did a litle cut/weld but thats it. 4wheelparts.com. doesn't hurt to check it out.
Old Aug 7, 2010 | 2:43 PM
  #17
2wd-K5's Avatar
a c-10 is 2wd like maxman04 said. not much point in lifting it, if u want to bog with it still and have some fun, throw on some 31X10.5's on the back and some 28" tires on the front (bigger will rub) and have fun, i have been in 2wd's like that before and it is sickly fun, the smallest puddle turns into a rooster tail lol, and with really knobby rears you can still take on a medium size mudhole. if you want to go bigger then u need 4x4, and in which case i would go with the 4" suspension (front springs and rear blocks) and 3" body lift then 35" tires will fit (with fender corner mods on the front) this is THE cheapest and easiest way to fit 35's under these trucks (unless u go with narrow tires but what good is that in mud?) 6" blocks in the rear spit out and therfore u must go with rear springs when lifting 6" and when lifting your truck and after, when u go bogging in it always dissconnect the anti roll bar and rear shocks, make that baby twist for you, i have worked on many trucks with the same set-up (tunning the engine for the bog weekends and such)
RUTRAKIN
Aug 7, 2015 11:05 PM
Simon-Pierre Lacasse
Mar 8, 2014 7:18 PM
Rlock4227
Feb 19, 2012 11:26 AM
akabavah
Avalanche
Oct 10, 2009 9:54 PM
