Swap'n it!!
Old Nov 9, 2006 | 10:32 PM
LOKI's Avatar
Default Swap'n it!!
Does anyone here know the Pros/Cons of swapping a 5.3l v-8 for the ss 6.0l? What would i need to do and about how much should i be looking at?
Old Nov 11, 2006 | 9:48 AM
BBBTHATROCKS's Avatar
Default RE: Swap'n it!!
One big pro is the power and torque difference. The 5.3 I was given as a loaner was junk. My 6.0 would walk all over it even though the numbers given out by chevy state that they are close in horsepower and torque. The loaner was a new 07 1500 crew cab I wasn't impressed.
Old Nov 11, 2006 | 11:38 AM
carpenterbill's Avatar
If you have the 4l60e trans you should swap it for the 4l80e. I have never seen a 6.0 bolted to a 4l60 and I am not sure if it will hold up.
I would look for a low mileage wreak at the bone yard. Then you would then have the engine, trans, puter, and any other parts you would need, IMHO.
The only con i would see is MPG, you pay more at the pump for that extra power.
What are you putting it in?
IMO, its the best iron block motor they make now, good luck with swap
Old Nov 12, 2006 | 9:38 AM
A question for Carpenterbill does the wiring harness match up to the 6.0 from the 5.3 or does that also need to be replaced?
Old Nov 12, 2006 | 1:04 PM
I am not sure if its the same or not.....sorry.
cueman
Feb 6, 2012 9:37 PM
