Old Aug 10, 2015, 2:35 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Steering & Suspension Guides
Print Wikipost
swapping leaf springs from 1500 to 2500/2500hd
Old Feb 19, 2023 | 4:47 PM
  #11
not 100% sure but i doubt if they would bolt up directly...the frames are completely different
Old Feb 21, 2023 | 7:42 PM
  #12
Halescott59's Avatar
Default $$$
Well I was stuck trying to find one that fits. When I realized I should just make one for. I am a welder so... I just need to find 6 lug Axel's. That's my current situation. Thanks for responding!
Old Feb 21, 2023 | 7:59 PM
  #13
that will be a tough one going from a semi floater to full floater and finding 6 bolt hub for a full floater, changing the pinion or driveshaft yolk, matching the diffs if 4wd
Old Feb 21, 2023 | 8:08 PM
  #14
I'm looking in salvage yards at the moment and found a lot. The one that will work with 6 lug's is expensive. It's an 07 that has low mileage. It's a 2500 4 leaf 3.73. I believe it is a FF Axel as well.
Old Oct 12, 2023 | 3:04 PM
  #15
JVM's Avatar
JVM
Originally Posted by Jason B
It will bolt right up. You will need longer u bolts and if you use the ubolts on the 2500hd then you will need to drill out hole on bottom plate so the ubolts will fit. The bottom plate on the 2500 wont work because of axle tubing size diffrence. I did it on a 2002 1500.
will 06 Silverado 2500hd leaf springs fit on an 02 Silverado extended cab 1500?
ekimw2500hd
Jun 26, 2012 10:16 PM
SILVERAD01
Sep 9, 2011 7:16 AM
usmarine0905
Apr 21, 2010 6:22 PM
ActiveMonkey
Mar 9, 2009 9:36 AM
kram5949
Mar 31, 2007 3:56 PM
