tbi 350 getting WAY to much fuel
Old Dec 9, 2024 | 8:15 PM
  #11
Estnly's Avatar
Originally Posted by steve242002
I'm having exact same issue. I've replaced the injectors, the fuel pump, the regulator, the forward temp sensor, tested the map and tps which are both good. Fuel psi is 11. Still won't start.... also new plugs, wires, cap, rotor, verified correct wire placement, verified spark, not sure what else to do.... also verified wire paths back to ecu.
Hi. Wondering if any of you guys had any luck solving this issue? Got the same thing going on.
Old Dec 30, 2024 | 7:00 AM
  #12
Badfall07's Avatar
Default Gas cap
Try changing your gas cap. Sounds dumb but, it has solved a few issues.
Old Jul 22, 2025 | 4:04 PM
  #13
iamyungkd's Avatar
any luck got the same problem with my 91
Ton of Fun
Jan 2, 2015 12:07 PM
themcguire
K5 Blazer
10
Jun 25, 2013 6:01 PM
simpsonracing
Mar 19, 2013 3:37 PM
macruadhi
Aug 9, 2010 9:23 PM
geozeke
Oct 19, 2009 3:17 PM
