Temp. Gage.
#11
RE: Temp. Gage.
I don't believe there is any coolant leaking. When I checked, I hardly had to add any since I got the truck. Then again, maybe just a slight leak maybe present? I haven't noticed any difference in the exhaust smell. I have come across coolant being leaked into the engine before and the exhaust would have a sweet, soapy smell if it did, correct?
#12
RE: Temp. Gage.
Well, changed the thermostat and so far the temp has stayed at a constant temperature.
ORIGINAL: wellmax
you may be losing so much coolant that the truck is getting hot. Only reason you have not overheated truck so far is because you travel such short distances.
I believe the coolant is going through engine as was stated on other replys.
Get a shop to test for engine coolant leaks. They can do that with dye and pressure on coolant system, I think.
I know some one on forum can tell you how this is done. If you do not fix the problem you will ruin the engine.
Fastest way to ruin a engine is lack of oil pressure, second fastest way to ruin a engine is lack of coolant, engine will over heat and seize.
Good luck and let us know what you find wrong with engine.
