Is there anybody out there that can help me?
I would like to put on 33x12.50 r20 on my 2003 1500HD with a leveling kit,but i was told i need a lift by one person and told they would fit just fine by another person,so i don't know what to do,can anybody help?.thanks.
Give it a shot before you buy the 20s.... The largest Ive seen in a non-lifted hd is LT285/65R18. This gives you a 32.7 * 11.50 on a 8.5" wide rim. Here is a good tire size chart. Its only for the BFGoodrich All Terrain TA but you can back out and look at any BFG tire and there specs..... Good Luck
http://www.bfgoodrichtires.com/specs...t-a-ko/44.html
You can fit 33" no problem. Crank the t-bars and you'll be just fine. If rubbing occurs, tie back the brake lines to the frame and trim the fender walls. Also good idea to cut the front valance a bit for fitment. Go to Diesel Place and search for H2 fitment... they are 33" tires.
ORIGINAL: Riccas
Mud_Truckin
Jun 4, 2009 1:53 PM
