Notices
timing an engine with SES light on.
Old December 3rd, 2009, 10:31 AM
davbell22602's Avatar
Default timing an engine with SES light on.
1990 chevy c2500 with tbi 350 setup but the vortec block/shell.
Can you time an engine with the ses light on? The haynes manual said to fix whats causing the ses light first before timing. I have buddies that timed engines with the ses light. They timed it, then fixed the cause for the ses light, and then re checked the timing.
Old December 3rd, 2009, 3:44 PM
Ride of the Month
May 2009
mudmaniac's Avatar
You need to disconnect the dist wire under the glove box to set the base timing. This eliminates the computer from the equation.
Old December 3rd, 2009, 3:48 PM
I dont have one. this is 90 truck not 96.
Old December 3rd, 2009, 8:50 PM
Professional Mechanic
MDTAHOE's Avatar
The truck absolutely has a set timing connector either under the glove box or near the fire wall. 1996 does not have one, you must time it using a scan tool.
Old December 3rd, 2009, 9:25 PM
Speedy650's Avatar
on the passenger side under the hood, theres a black cover. remove that cover and their is i believe a purple wire with a black stripe on it. it has a disconnect, unhook that, set your timing, then re-connect (i believe after you shut the truck off) and you should be good to go.
Old December 4th, 2009, 6:32 AM
dmann13815's Avatar
don't forget to dissconnect the battery to reset the engine light after your done.
Old December 4th, 2009, 7:07 AM
Ride of the Month
May 2009
mudmaniac's Avatar
This is the method you must use on Chevy trucks with TBI from 87 - 95
Old December 4th, 2009, 8:18 AM
So its ok to put it in time when the ses light on?
Old December 4th, 2009, 8:39 AM
MDTAHOE's Avatar
It can be done if you have too, as long as the idle speed is not beging affected by the problem causing the CEL.
Old December 4th, 2009, 10:02 AM
ok, well right now its too far advanced. Talking about the engine racing bad after running 10-15 seconds.
Quick Reply: timing an engine with SES light on.
