Tire Pressure Monitor System
Old Sep 21, 2009 | 6:10 PM
delucaj's Avatar
Default Tire Pressure Monitor System
Is it possible to set the TPMS system to a lower pressure. My 2500 wants 60psi or if flashes a warning.
Old Sep 21, 2009 | 8:40 PM
MDTAHOE's Avatar
Professional Mechanic
It maybe able to be done by the dealer. I doubt any independent shop will have the equipment to reprogram.
Old Sep 21, 2009 | 11:12 PM
jwruss's Avatar
I was told by my dealer that my system could be reprogramed for different tire sizes but not for pressure, which to me seems totally stupid since different tire sizes can take different pressures. Not to mention different load ranges will have different pressures.
Old Sep 21, 2009 | 11:31 PM
Speedy650's Avatar
or, have the sensor turned off and do it the old fashioned way of taking 30 seconds once a month to walk to each tire and check it by hand. Problem solved?
Old Sep 22, 2009 | 5:36 PM
therewolf's Avatar
Your 2500(HD I'm guessing?) has the ten-ply 80PSI rated E-radials. Or it did at one time, hence the high pressure rating on the TPMS . 60PSI is the recommended pressure for these tires at the front of the vehicle.
Hey don't kill me, I don't even play piano that well...
ladyz
Mar 19, 2014 3:57 PM
Pugly
13
Feb 27, 2014 9:59 AM
shirley246
Jul 19, 2011 2:45 PM
fe_pony
Mar 22, 2008 7:33 PM
nighshifter
Aug 20, 2007 10:41 AM
