Last edit by: IB Advertising
- Chevrolet Silverado: What is Maximum Towing Capacity?
Important information to help you understand your Silverado.
towing capacity
to determine your tow capacity you will also need to know your differential ratio.
the code is listed on a tag in glove box on many models.
fine your code and someone on forum can tell you the ratio number.
Gq1 -- axle rear, std ratio
gt4 -- axle rear, 3.73 ratio
gt5 -- axle rear, 4.10 ratio
gu4 -- axle rear, 3.08 ratio
gu5 -- axle rear, 3.23 ratio
gu6 -- axle rear, 3.42 ratio
g80 -- axle rear, limited slip (positraction)
hc4 -- axle rear, 4.56 ratio
ChevySoldier
January 8th, 2008 5:58 PM
