Trailer brakes - No tow package.
Old Nov 19, 2007 | 9:28 PM
8KCAB's Avatar
Default Trailer brakes - No tow package.
I have an '04 Chevy. It came with a hitch and 4 way plug. I added the brake controler, and hooked up the red line to the #2 stud and the bluw wire to the blue wire with supplied plugs in the fuse box. Now I need to wire a 7way plug in the back. The lights ect. are simple enough, because I just use the lines which were in the 4way plug. But which wire is for the trailer brakes? I would guess blue, but the left turn are quick-tapped into that line. Any suggestions? Thanks.
Old Dec 25, 2007 | 6:15 PM
old dog's Avatar
Default RE: Trailer brakes - No tow package.
take a look in your owners manual they usually give you some guinence as to wire colors in the trailer towing section ,if your truck did not come with a factory hitch there might have been a 7 wire plug provision ther neer the spair tire with a dust cover pushed in it ,or not or a harness just taped up in the rear harness that will be label with a white tag .if the black plug with a dust cover is there yo7u can just plug a sealed 7 wire pluginto it made by drawtite #20012for the bracket 20015 for the plug
Kevin8520
Nov 30, 2014 8:45 PM
Daju
Jun 28, 2014 10:19 PM
cupandbook
Camaro
Jun 5, 2014 10:36 AM
KC Bobber
Oct 18, 2007 9:24 PM
adjmcloon
Feb 6, 2007 7:05 PM
