Old Aug 10, 2015, 6:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Towing & Hauling Guides
Print Wikipost
trailer wiring 2008 silverado
Old May 30, 2010 | 2:47 PM
66pross's Avatar
Default trailer wiring 2008 silverado
what to hook up to get power back to the plug for aux lights inside my trailer? My truck has the factory brake contoller,and I hooked up the wire that was taped up and that didn't send power back to the plug?
Old May 30, 2010 | 3:02 PM
I know on the Tahoe's there is a wire that is also taped up under the hood to provide power to the trailer harness, should be red and have a ring terminal on it right under the brake booster
Old May 30, 2010 | 9:41 PM
old dog's Avatar
Default 12 volt lead
i am not sure about the factory installed brake control but usually you have to install a 40 amp fuse to activate the circuit ,check your owners manual first for location .here is a good copy from e trailer on their controller installation and they talk about just adding a fuse at the very end of the article .you can also e-mail them to see if they can help you .
http://www.etrailer.com/faq-brake-co...silverado.aspx
intheknow
Jul 24, 2014 10:38 AM
The02Riot
15
May 23, 2014 11:54 AM
Rosariods
Jul 21, 2011 8:13 PM
sswarin
10
Apr 1, 2010 2:23 AM
akcirocz
Jul 27, 2008 9:10 PM
