Trans not shifting speedometer not working
Old Aug 10, 2015 | 12:33 PM
Merkel3594's Avatar
Default Trans not shifting speedometer not working
Truck just started acting up. When on drive it does not shift. I can manually drive in first and second, not third. And the speedometer quit working as well. Buddy thought it was the shift selonoids so changed those still nothing. Any ideas?
Old Aug 10, 2015 | 2:29 PM
burnhedge's Avatar
It would help if you fill out your profile so we know what truck/trans you have.
Old Aug 10, 2015 | 10:05 PM
KChevy75's Avatar
Possible busted sprag in the forward sprag assembly. Do you have Reverse? What vehicle, engine and trans?
Old Jun 4, 2021 | 2:39 PM
Armylyfe's Avatar
I’m currently experiencing the same thing. Truck drives fine in reverse, 5.3-4L60e. All gauges work except speedo, new VSS installed, checked all fuses
Old Jan 7, 2022 | 10:33 PM
Tlg1371's Avatar
Default Similar problem
Im new to the forum and a first time suburban owner. It's a 1999 k2500. One day the speedometer quit working. And I noticed reverse gear seemed to be slipping. The next day, no reverse gear at all. I've replaced the transmission output sensor. Crickets. I noticed a couple ground straps had rusted in 2. I replaced them, no luck. And now I've noticed I don't have low gear. I have D, 3rd, and 2nd. It's a 4L80-e transmission. And wisdom will be greatly appreciated. You don't realize how much u need reverse until u don't have it. Lol
rwolfgram10
Nov 23, 2014 8:08 AM
russianbear10
Jul 20, 2012 8:44 PM
cdbrock24
Mar 27, 2012 11:51 AM
chevyfiesta
May 22, 2011 3:24 PM
