Transmission "slam"???
Hi, I'm new to the forum so please go easy on me.
I have read alot of the post's about transmission problems but my2001 Z71does something slightly different to the other prob's posted.
When I pull away from a standstill the transmission seems to "slip" slightly and then slam forward.It's a weird sensation which feels like something heavy rollling from the front of the bed to the back and hitting the tailgate (obviously it's not that as the bed is empty).sometimes it does it as you move off and other times it happens after you have gone a few yards and is accompanied by a squeak.If I pull off really gently it doesn't do it so much.The truck shifts smoothly through all the gears and there isn't any strange noises or vibrations.
Any ideas or help is appreciated as I am in the UK so no dealers.
Thanks
Thanks
RE: Transmission "slam"???
Welcome to the forum!!! Sounds like you need to check your u-joints, they may be worn. How many miles/kilometers are on the truck?
Hi, The Truck has done 108,000 miles,
I can't see or feel any wear or play in the joints but I know this doesn't mean they are ok.Would the u-joints cause the problem? I have rebuilt and off-roaded lots of Landrovers for the past 10 years and have never had symptoms like this from the u-joints.
It feels really strange
Not completely sure, I was just throwing the first thought Ihad out there. My second throughtwould be the trans, is the truck throwing acodeor check engine light on?
sounds like the fluid might be a bit low.....trans would slip untill the fluid gets flowing then puts it into 1 gear while at a high rpm causing it to slam into gear
Coravir
October 26th, 2019 3:28 PM
DSGB
May 29th, 2013 8:54 AM
vfilby
April 15th, 2008 11:10 PM
