Transmission problem
Old January 4th, 2010 | 5:43 PM
Billytk's Avatar
Default Transmission problem
I have a 1998 <NOBR style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id=itxt_nobr_0_0>chevy</NOBR> ck1500 with a 4.3l vortek and 4l60e trans. Driving to work one morning the trans acted like it popped into neutral, when I got below 50mph it went into third and stayed there. I could manually get second and reverse but no first or fourth. Also the check engine light went on. If I shut the truck off then restart it drives normal for a few hundred miles then it happens again. I checked the code and it came up "shift solenoid B electrical circuit". I replaced both A and B solenoids and it still does it every couple of hundred miles. took it to a trans shop and they think it might be the computer but not sure.
Old January 4th, 2010 | 9:35 PM
MDTAHOE's Avatar
Professional Mechanic
That is in the year when GM trucks had problems with the ignition switch, it would drop the trans circuit off therefore killing power to the solenoids. The switch is relatively inexpensive and maybe worth trying.
Coravir
October 26th, 2019 3:28 PM
Gregg
August 4th, 2015 9:08 AM
DSGB
May 29th, 2013 8:54 AM
vger105
December 5th, 2006 4:23 PM
Pbce888
November 10th, 2006 12:09 PM
Quick Reply: Transmission problem
