Transmissions 89 Z71
You could use that same steering column, you would just need to put in a floor mount shifter. Other than that flywheel, cause of clutch plate surface, and driveshafts. They will most likely be shorter on back and longer on front. You will need a tranny cooler, if your radiator dosen't have a spot for the lines you will need a good sized aftermarket one or a new radiator for an auto. As long as you get a troque converter with the tranny that should be it. I May be missing something though. You may need a new crossmember. Good luck.
Danistheman1234
Mar 7, 2021 10:20 PM
