truck stalling
truck stalling
i have a 1996 chevy k1500 5.7 liter iv had the fuel pump and filter replaced then it was blowing fuel ecm fuse not it still has trouble starting /and stall now and then does anyone have any suggestions on how to fix it
OK, slow down there a little, Kemosabe'.
What symptom spurred you to change the fuel pump and filter in the first place?
if you just had the pump replaced and now its blowing the fuel pump fuse, the wire harness is probably being pinched and shorting out... lower the tank a bit and see if you can inspect the wire harness to the pump....
Please work on you're spelling and punctuation so we help you out with your problem!
T Palen
September 29th, 2013 2:21 AM
Spike44
January 21st, 2005 11:58 AM
