truck stalling
Old May 17, 2009 | 3:10 AM
bhaynes's Avatar
Default truck stalling
i have a 1996 chevy k1500 5.7 liter iv had the fuel pump and filter replaced then it was blowing fuel ecm fuse not it still has trouble starting /and stall now and then does anyone have any suggestions on how to fix it
Old May 18, 2009 | 11:58 AM
therewolf's Avatar
OK, slow down there a little, Kemosabe'.
What symptom spurred you to change the fuel pump and filter in the first place?
Old May 18, 2009 | 3:09 PM
if you just had the pump replaced and now its blowing the fuel pump fuse, the wire harness is probably being pinched and shorting out... lower the tank a bit and see if you can inspect the wire harness to the pump....
Old May 18, 2009 | 3:53 PM
suzuki-guy's Avatar
Please work on you're spelling and punctuation so we help you out with your problem!
Old May 18, 2009 | 5:28 PM
Thumbs up
On that note, if you use Google Chrome is has a built in spell checker, really nice to have if you do a lot of blogging or forum-ing
Old May 19, 2009 | 6:39 AM
bhaynes's Avatar
i replaced the pump after it went out while i was offroading
ggilhamca92
Feb 20, 2014 12:29 PM
T Palen
Sep 29, 2013 2:21 AM
jamesdal7
Nov 6, 2009 5:33 PM
anmlfrnd
Feb 3, 2006 1:05 AM
Spike44
Jan 21, 2005 11:58 AM
