Truck started smoking!
Old Oct 10, 2012 | 6:10 PM
88stepside's Avatar
Default Truck started smoking!
I have a 1988 Chevy k1500 stepside shortbed. It runs good, have no issues when running. Been a great truck so far. When i start it up it smokes out of the exhaust for a couple of minutes but once it warms up it doesn't smoke again. I've been told its burning oil and it could be the valve seals. If anybody has any insight to what it might be or could help me find something to help me analyze the problem and fix it. I'm researching online but you know how that goes as well. Thanks for any help given.
Old Oct 10, 2012 | 6:26 PM
Fishinfooleric10@aol.com's Avatar
I would say the piston rings are probably worn and on cold start it smokes and when your motor heats up they expand and doesn't let oil leak on the top of the piston where it burns the oil. I mean I believe it to be straight forward that it's more than likely the piston rings and to fix it is to replace those. I'm just saying unless this is something you want to get into and replace those, I have seen em run for a long time burning a little oil and I wouldn't worry about it too much except to check oil to make sure you don't burn off too much.
Old Oct 11, 2012 | 6:06 AM
88stepside's Avatar
Yeah I figured it would be something major. Ill just leave it alone as long as it running good. Jus t trying to take care of it so it last another 25 years lol.
Old Oct 11, 2012 | 11:49 AM
Yep all you can really do is drive it until it won't move anymore and then drop another motor and keep on going
exhumis
Nov 26, 2014 8:54 PM
alamozgreat
Aug 17, 2011 11:08 PM
tom5170
16
May 9, 2010 11:55 PM
98Silverado1500
Mar 3, 2009 11:34 PM
sage0501
Mar 29, 2008 12:38 PM
