Truck still Shakes
Old Sep 4, 2010 | 10:06 AM
  #11
therewolf's Avatar
"Desert Storm"?? Are these by any chance solid rubber tires?
Old Sep 27, 2010 | 3:08 PM
  #12
dadssilverado's Avatar
Not that I know of or research online. I ended up finding a shop that uses the Road Force machine and pretty much fixed all my problems. There is still some shake but now I cant tell if it's just b/c I don't use as much tire as the stock or it's b/c the wheels are still bad... but I can live with it for now..
Old May 10, 2011 | 9:08 AM
  #13
shanec's Avatar
Which shop? I'm in Brandon and I'm in need of Road Force balancing.
Old May 11, 2011 | 8:39 AM
  #14
Shanec, you get my message?
Old May 11, 2011 | 9:53 PM
  #15
country_09's Avatar
the road force balance pretty much fixed it? I need to get this done on my 33s because mine shakes between 40-50...how much did they charge per tire to balance em?
Old May 12, 2011 | 6:53 AM
  #16
shanec's Avatar
I did. I am going to try to get this thing fixed on Friday.
Thanks!
Old May 12, 2011 | 1:35 PM
  #17
It was like $25 for all 4 tires. Really a steal if you ask me. Yes it pretty much fixed it, but you have to make sure you have hub centric wheels as well, otherwise you will not fix the problem.
Old Nov 13, 2020 | 8:41 AM
  #18
Joel Mccrudden's Avatar
I am at a loss: Truck continues to shake between 60 - 70 mph and the ride is considerable rough/bouncing:
History:
06 Silv LS modes:
22's 305/50/22 tires
New Adjustable Gabriel HiJacker shocks in the back
Brakes have been checked (good)
Tires have been balanced twice
Alignment has been done twice and I have replaced the tie rods
For the past 4 days I have taken this truck to two shops and they both say the have it fixed but the shaking is still very annoying at the speed given above. I do realize that the comfort of the ride will be different given the change of wheels/tires but come on this is horrible.
I don't know what else to look for to change in order to, at least, stop the shaking/vibrating at 60-70 mph? Where do I go from here? I'm tired of dropping it off at the shop every morning and hitching a ride!
Suggestions? YES - I have used the "search" feature but nothing seems similar to my problem?
Try having the drive shaft true done and balance
Theophylaktos
Sep 13, 2021 4:55 AM
jmckeage
Nov 10, 2009 7:21 PM
dtipainter
Nov 2, 2007 10:46 AM
sethlives1
Cobalt
Oct 7, 2007 7:39 PM
