True or False
Old Oct 10, 2009 | 12:40 PM
cb1's Avatar
cb1
Default True or False
Is there a quick way to tell if an engine has low miles without tearing it apart? I always get scared when someone wants to sell me an older engine with very low miles.
Old Oct 10, 2009 | 2:53 PM
desrtrat's Avatar
the only thing i can think of, is pull the spark plugs and get a scope and look into the cylinders far ware. other than that... buyer beware
good luck
Old Oct 10, 2009 | 2:58 PM
therewolf's Avatar
How accessible is the engine? Pull the valve cover, if it's low miles, it should look it.
Is the engine still running in the truck? If there's a tachometer, watch the engine at idle.
On a low-mileage engine those nylon timing chain gears won't have sheared off many teeth, and you should have a smooth idle.
Pull the distributor cap, once again, if the engine is low miles, it'll look it.
Old Oct 10, 2009 | 4:11 PM
Speedy650's Avatar
how much of an older engine?
Old Oct 10, 2009 | 6:42 PM
cb1's Avatar
cb1
It's a 93 and located at a salvage yard. They say it has 48,000 on it.
Old Oct 10, 2009 | 7:08 PM
mudmaniac's Avatar
Ride of the Month
May 2009
I think I would ask how long they have had it. It may have sat around for a long time, and under what conditions.
Old Oct 10, 2009 | 7:53 PM
Mike Sigmond's Avatar
ROTM Coordinator
Was it in a wreck? is it still in the car? if so I bet the mileage is correct, unless they are just making stuff up to sell the motor.
I wonder if you can get the vin # and look up when it was filed a non-op. at the DMV, MVD or whatever they call it where you are.
Good Luck!
JAJohnson911
Aug 2, 2015 1:43 PM
edwaybid
14
Jan 22, 2014 9:26 PM
JCRAMOS
Jan 9, 2010 10:41 AM
robin
Apr 20, 2006 4:48 AM
