turn signal switch assembly
I changed the steering column on a 81 chevy pick-up ,replaced it with a column from a newer model truck. I had to change out the ignition switch on the newer column I was going back with the turn signal assembly it has 2 metal clips one large the other small I cant recall where the small metal clip goes. can you help?.
fishingpro77
HHR
August 4th, 2016 12:44 AM
Doug Williams
February 22nd, 2012 10:16 PM
RomanGuzi
October 2nd, 2011 11:40 AM
