Venture 1997-2005
Platform: U-Body
Front turn signal/parking lamp assembly
Old Jan 31, 2008 | 9:19 PM
dkh96825's Avatar
Default Front turn signal/parking lamp assembly
I have a Chevy Venture 2003. The daylight running lamp is burned out and I want to replace it. The owner's manual says to unscrew the thumbscrew and pull the assembly away from the vehicle.
Did that, but the assembly seems to be hanging on something.
Anyone have any experience with this?
Thanks in advance.
Old Feb 1, 2008 | 1:06 PM
cbr600rrnut's Avatar
Default RE: Front turn signal/parking lamp assembly
Once you remove the thumbscrew the lens has a tab at the bottom of the lens on the headlight side of the lens which has a metal clip on it which inserts to a holder to secure that portion of the lens. Pull out on the headlight side of the lens to unclip the clip. On the fender side there are 2 plastic prongs which are inserted into 2 holes to align and to secure the lens on the fender side of the lens. hope this helps.
Old Feb 15, 2008 | 3:29 AM
dkh96825's Avatar
@cbr600rrnut
Thanks for the help. I got the daylight running lamp lens out and changed the bulb per your instructions.
Now I find that the metal clip is missing and I now I have a new challenge, finding a replacement clip. LoL
Old Feb 19, 2008 | 4:05 PM
SailorJohn's Avatar
It should all go back together without the clip. The first time I changed the bulb on my 2000 Venture the plastic post that the clip is mounted to busted. I put it back together and once I tightened the thumb screw you couldn't even notice.
Old Feb 21, 2008 | 7:44 PM
dkh96825's Avatar
ORIGINAL: SailorJohn
Yeah it goes back together all right and looks all right. It's just knowing something is missing. LoL
Doug Williams
Feb 22, 2012 10:16 PM
Mille Racer 69
Mar 14, 2011 3:19 PM
flowerodesert
Sep 21, 2010 12:37 PM
oldmako
Jun 17, 2008 11:00 PM
