u-joints
Old Jul 2, 2011 | 9:58 PM
kevan Mulherin's Avatar
Default u-joints
2003 silverado 2500 HD 115,000 miles. At low speed, low pitch, metal scratching noise coming from under truck. Maybe drive shaft. Noise goes away at higher speeds. Noise occurs at low speed acceleration. However, stops when I let off the gas. I think this condition may be u-joints. Not sure.
Old Jul 2, 2011 | 11:20 PM
skeeter5's Avatar
Kevan,
The best way that I know of is to pull the drive shaft and work the u-joints by hand. If they are not smooth, they will need to be replaced.
Old Jul 2, 2011 | 11:49 PM
Mille Racer 69's Avatar
take a greese gun and make sure they are lubed up.
you should keep pumping til you see it start to peek out of the base
Old Jul 13, 2011 | 10:02 PM
tdubbz226's Avatar
Just take driveshaft and wiggle it up and down while turning it slowly. if you have any play the u joint should be replaced. mine made a clicking sound when bad.
Old Jul 14, 2011 | 8:48 AM
OLD WRENCH's Avatar
Sounds like classic U-Joint noise to me.
redlines4me
Aug 18, 2009 8:46 PM
quinnman105
Nov 24, 2008 1:53 AM
snowboarder4life
Oct 8, 2008 8:28 PM
hometheaterman
Mar 30, 2008 2:07 PM
sthole
Apr 29, 2006 9:44 AM
