V8 Vortec Swap Misfire Issue
Old Dec 27, 2010 | 8:32 AM
aapstealth's Avatar
Default V8 Vortec Swap Misfire Issue
I currently Finished swapping a 1997 Vortec 5.7 V8 into my 97 Vortec V6 K1500 pick up truck. I changed over the Wiring harness Computer sensors etc. The truck Fires up and Runs great but as Soon as I plug in all the O2 sensors the Truck starts to have a misfire. I tried resetting the ECU but the same issue occurs. Once I turn the truck off and unplug the 02 Senors it begins running normally. The senors were working fine on the 1996 Vortec and I never even had a check Engine light on. I looked up the sensors and there are the same number of sensors and types of sensors on the V8 Truck I pulled the Engine out of. Also the truck I removed the engine from had No misfire or anything and All sensors were attached. Any thoughts or Ideas on this Issue?
Old Dec 27, 2010 | 5:25 PM
2wd-K5's Avatar
did you use the map sensor from the v8?, also check the connections into the computer for bent pins or something, this is wiered though
Old Dec 28, 2010 | 12:01 AM
6LCHEVYZ71's Avatar
Make sure you have the plug going to the correct sensor. i.e. bank1 sensor1 to bank1 sensor 1
Does the truck run differently when the sensors are plugged in or does it just throw the code?
jguill
Apr 6, 2021 1:02 PM
buddyleno
Mar 31, 2017 8:13 AM
ford with a chevy
Apr 11, 2013 1:37 PM
GoChevy
May 20, 2010 10:54 PM
Biggumzmcgee
Nov 15, 2009 10:51 AM
