Very hot interior.
Old May 26, 2012 | 5:44 PM
lowred1's Avatar
Default Very hot interior.
I have a 94 Chevy 3500. I would like the interior around my feet to be better vented. It gets really hot down by my feet. I mean hot. It's O.K.if I use my A.C. but I like to run with my windows down alot. Is there a way to get the outside air to blow down on my feet like the old trucks with that little lever that would let air in down by your feet. I thought someone may know a trick or two. Thanks
Old May 26, 2012 | 6:34 PM
Doug Roberts's Avatar
Pull fuse for heater some times will help I had a s10 that the heat was always on but never heard a thing or link heatcore hose . if its a standard get a aluminum pan for transfer hole then put boot back on
Old May 26, 2012 | 10:37 PM
Turn the A/C on with the compressor off. That will only run the fan. Switch the vent to blow air at your feet. I do it a lot and it works.
Old May 29, 2012 | 7:38 AM
lowred1's Avatar
Thanks I'll give all those ideas a try and post my results. Thanks again
Old May 29, 2012 | 9:33 AM
TRUCKSTUFF's Avatar
I have turned the AC on while the compressor is off and it does indeed work so you should definitely try that.
mdm6713
Dec 30, 2019 4:41 PM
mattycakes
Oct 15, 2013 10:58 PM
CDC
Jun 13, 2007 6:24 PM
buijon
Dec 15, 2006 6:07 PM
billyjoe72
Oct 21, 2005 4:33 PM
