Vibration when in 4 cyl mode?
I have an 08 1500 Silverado NBS with the 5.7 V8 where the computer will shut off half the cylinders when not needed. When I bought the truck I'm pretty sure that I didn't notice any difference when it switched from 8 to 4 and that while in 4 the engine was fine.
About January this year I started to notice that when in 4 the engine has a differnent pitch as I could also feel a difference like a vibration in the gas pedal.
Is this normal? Do they all do this?
My truck has been to the dealer more times then I care to mention and when I spoke to them on the phone I got the "they all do that answer" but was told if I wanted to bring it in to do so. I could take the few hours to go and do it but like I said I'm tired of seeing the dealership on a truck with only 18k miles on it.
Any thoughts? Suggestions? I don't notice a difference in performance it's just more of a noise/vibration that I am feeling.
Classifieds Moderator
TruckForums Liaison
TruckForums Liaison
I would assume it would sound a little higher pitched because your losing that V8 rumble and you have a 5.3 not a 5.7.
I don't know about the vibration but to be honest with you those aren't things that I would worry about too much, if it gets worse I would but...to each his owwn
I didn't notice any vibration whatsoever during the 2 highway gas mileage checks of 23.7mpg and 22.0mpg . . . . but then I don't even know if it ever switched from 8 to 4 cylinder . . . . although I would assume that it did to get that kind of gas mileage . . . at 60mph and with the 3.42, the tach was consistently reading 1600rpm . . . . the lowest cruising speed rpm I have ever had at 60mph on any vehicle
TruckForums Liaison
TruckForums Liaison
Alright 98white5.0, I hate to break it to you, but LOOK AT THE NAME OF THE FORUM! I DON'T CARE ABOUT DODGE TRUCKS NOR WILL I AND THIS GUYS TRUCK IS A CHEVY SO YOU CAN JUST GO WALLOW IN SELF PITY WHILE I TRY AND GET OVER THIS ABSURDITY
winterlion
March 30th, 2013 4:32 PM
philgethifi
16
May 27th, 2009 11:52 PM
