Volant Ram Air Problem - Help
Old Feb 18, 2008 | 7:28 PM
rig70's Avatar
Default Volant Ram Air Problem - Help
Hi Everyone! I installed the Volant CAI today... I must say... directions SUCK! I am not a mechanic by any means - having said that, it still only took me 2 hours to install- not bad.
Do you guys have fog lights? The ram air would not fit due to the foglight assembly. Am I doing something wrong? I am frustrated since I installed the entire thing, but could not get the ram air to fit. I'm also a bit uncomfortable with the fit of the air tube to the throttle body (having to use the old gasket). Any advice is appreciated. Thanks!
2005 2500 HD Crew
Old Feb 19, 2008 | 4:09 AM
fireman526's Avatar
Default RE: Volant Ram Air Problem - Help
I would try contacting volant directly, maybe they sent you the wrong kit? Or maybe that kit doesnt work with trucks with foglights. Sounds like the tube goes where the foglight is.
Old Feb 19, 2008 | 6:51 PM
rig70's Avatar
My bad... I have a plow adaptor on the front of the truck. Was on there when I bought it... I called tech support (they are great!) ... have to remove the plow adapter and it should fit perfect.
Old Feb 21, 2008 | 9:33 PM
fireman526's Avatar
Yeah I talked to someone else who had a Volant with foglights and they said they didnt have any problems. Glad you found what you needed.
DublDown
Dec 6, 2017 11:13 AM
cyberghost
10
Oct 4, 2010 1:38 PM
RayenTiger
Feb 23, 2009 4:18 PM
Jungle Jim
Jan 1, 2009 8:53 PM
peterpiepr
Nov 30, 2008 8:31 PM
