What to do next to engine?
Old June 22nd, 2010 | 10:45 PM
RedwoodChevy's Avatar
Default What to do next to engine?
Alright so i currently have a k and n cold air intake and flowmaster exhaust. I purchased a Hypertech Max power programmer and am waiting for it in the mail, but I don't know what the next place to start would be. I have a 5.3 V8 and its a 2008 Silverado. Let me know your thoughts, I have considered a throttle body spacer but I don't know if that will do anything.
Old June 22nd, 2010 | 10:58 PM
s34n's Avatar
ive heard that it doesnt do much for the motor. im just spitballing but could upgrade your cams.
Old June 22nd, 2010 | 11:20 PM
72c10gunn's Avatar
Headers and a mild cam would really unleash some power but may require custom computer tuning
Old June 22nd, 2010 | 11:34 PM
thanks, would you happen to recommend any companies for cams, cause i honestly don't know anything about them
Old June 23rd, 2010 | 12:33 AM
s34n's Avatar
check out summitracing.com
Old June 23rd, 2010 | 3:04 PM
Hypertech's Avatar
Redwoodchevy, Thanks for supporting us and I hope your happy with your new programmer
Old June 23rd, 2010 | 4:04 PM
SilveradoShane413's Avatar
Headers and Lighter Pulleys, I didnt really see much with the throttle body spacer myself.
Old June 23rd, 2010 | 6:32 PM
s34n's Avatar
ive heard that long tube headers are better then the shorties. so keep that in mind.
Old June 24th, 2010 | 10:35 PM
See what makes the longtubes better?
Old June 25th, 2010 | 8:43 PM
s34n's Avatar
the longtubes give a much wider spectrum in regards to the torque output. through the rpm range. whereas the shortys give a much closer torque range in your rpms. but with long tubes you wont use the factory y-pipe. youll have to find a spot for it somewhere between the pipes and cats. with the shortys youll use the factory y-pipe.
Trick Concepts
March 19th, 2007 9:02 PM
TMW597
January 7th, 2007 11:25 AM
drewsm3
July 26th, 2006 9:22 PM
Sea Dub
Uplander
January 26th, 2006 5:00 PM
Sea Dub
Uplander
Quick Reply: What to do next to engine?
