what should i get???
Old Jun 25, 2009 | 1:22 PM
  #21
89silverado283's Avatar
ok do i need to know anything about switching the injecters before i tear it apart??? and about the going up a hill any thoughts on maybe a super charger or maybe a procharger???
Old Jun 26, 2009 | 1:22 AM
  #22
Blindsight's Avatar
Before you consider forced induction, try the injector swap. I don't know much about the process, but injectors that don't allow enough fuel to flow will cause the vehicle to run lean, especially in higher RPM ranges, so having the correct injectors could essentially solve your problem.
Old Jun 26, 2009 | 6:52 AM
  #23
mudmaniac's Avatar
Ride of the Month
May 2009
You simply remove the top of the fuel pod, remove the injectors and drop in the new ones. If you want to disconnect the fuel lines you can replace the whole fuel pod from one TBI to the other, this would include the pressure regulator.
chevy619
19
Feb 5, 2012 8:42 PM
country_09
Jul 23, 2009 2:21 AM
EV42TMAN
Dec 12, 2008 7:14 PM
