what transmission do I get for the 4x4 1988
Old Mar 21, 2012 | 7:43 AM
  #11
jesse06's Avatar
I pulled the PCV tube off the front of the carburetor. Its running a bit higher RPM and whistles, but its not going into spittering and sputtering nearly as much. maybe like 10% as much as it was. It will get me by untill I can put it in the shop. I cant afford nothing for almost a month.
Old Mar 25, 2012 | 4:08 PM
  #12
jesse06's Avatar
Default problem solved
I replaced the EGR the PCV and the air idle controler module. On the side of the carborator... Now the truck is running fine.
Old Jan 5, 2022 | 8:48 AM
  #13
Jack007's Avatar
Default 88 Silverado 4x4 trans
Originally Posted by Gundog
You have a 700r4 if it is an automatic.
I just bought an 88 4x4 and it’s not kicking into overdrive. Is there a lockdown cable for this? If so, where is it located? I only see a throttle cable connected to the carburetor. It has been converted to carburetor “quadrajet” from fuel injection. All help appreciated
Old Nov 13, 2022 | 8:03 AM
  #14
Philuponya's Avatar
You have a 700r4 if it is anautomatic.
So my trans tag says its a 4l65e and not a 700r4 I have an 88 swb Chevy K1500 4x4 with a 350 v8. How can I know 100% what trans I have.
Rsill
Apr 1, 2021 5:32 PM
chevy619
19
Feb 5, 2012 8:42 PM
damlaspiker
Jul 29, 2009 11:14 AM
Flying Low
Corvette
Mar 29, 2009 7:56 PM
