Wheel Removal
Old Oct 22, 2015 | 9:38 AM
scott79's Avatar
Default Wheel Removal
This has been an issue since i have owned the truck. I cannot get the Rear Wheels off the truck. In the past i have used a 2X4 to pry the wheel off or kick it REAL hard. Sprayed KROIL around the studs , still stuck. i even let the jack down , it wont pop off.
Any ideas ?
Scott
2002 HD
Old Oct 25, 2015 | 3:54 PM
scott79's Avatar
I cannot believe anyone has a solution for this. Anyway i got the rear wheels to break loose after i kicked an kicked it loose. Also i cleaned all the rust off the Aluminum wheel and applied never seize where wheel makes contact with rotor
Old Oct 26, 2015 | 2:20 PM
99 Silverado 3 door's Avatar
I don't have nice rims to worry about so when I take the tires off I just smack the rim with a heavy hammer. I keep doing that from each side until it pops loose.
Old Oct 26, 2015 | 3:44 PM
fparkin's Avatar
or loosing lugs and make a couple turns breaks them loose every time
