where is it?
Old Jul 15, 2009 | 5:51 PM
gaftop1's Avatar
Cool where is it?
94 reg cab 1500 4.3 4l60e?
have a knock sensor code and a code 67. where is the knock sensor? do they go out often?
the 67 code says in one book that it is a a/c low pressure in another one it says it's a tcc solenoid. help!!!!!
Old Jul 16, 2009 | 10:03 PM
lukemoore646's Avatar
the knock sensor is on the pass. side of the block where there is usually a 1/4 inch pipe plug, it goes into the coolant. if its not unplugged tap lightly on the block by the sensor with a small hammer while it is running. if it is working the engine will stumble and if that happens you better look elsewhere. my 93 throws a knock sensor code but it really needs a distributor, wierd
