The whole sets of LED Upgrade Guide| Chevy Silverado 1500 2019-2021
Old Dec 13, 2023 | 10:29 PM
LASFIT's Avatar
Former Sponsor
From: 9155 Archibald Ave Ste. C, Rancho Cucamonga, CA 91730
Default The whole sets of LED Upgrade Guide| Chevy Silverado 1500 2019-2021
When upgrading your Silverado, the lighting system is a big deal. In fact, adding LED lights not only gives your Silverado a brand-new look, but also greatly improves driving safety at night. The upgrade process is not difficult, as long as you confirm the bulb size to be replaced. We have listed all the bulb sizes of the halogen lights of Silverado 1500 2019-2021. You can purchase the correct LED bulbs based on the bulb size.
OEM halogen bulb size:
Low Beam: H11
High Beam: 9005/HB3
Front Turn Signal Light: 7440/7443
Back Up Light: T15/921/912
License Plate Light: T10/168/2825
You can try Lasfit LED bulbs on your Silverado 1500. These lights are high-quality products tested by Lasfit, which can bring a brand new lighting experience for your Silverado 1500. I believe that once you try them, you will be impressed by their excellent performance.
Low Beam: Pro-CS-01L LED bulbs
Lasfit Pro-CS-01L were specially designed for 2019-2021 Chevy Silverado 1500 with stock H11 halogen bulbs. The custom-fit dust covers are built-in turbo cooling fan to work with LED bulbs for quick heat-dissipation and protect the LED bulbs from water and dust. Truly 50W/bulb, 5000LM/bulb. Plug and play installation. Definitely smart choice!
High Beam: LAplus 9005 LED bulbs
We would like to recommend Lasfit LAplus series 9005 LED bulbs to work on Silverado. 30W, 3000LM per bulb, 6000K bright white. They are built without an external driver directly plug and play. New cooling system with a unique ball-bearing fan for heat dissipation, and upgraded LED clip to ensure ultra-high luminous efficiency.
Front Turn Signal Light: T-7440A(amber) for WT/RST/LT/LTZ/High Country T-7443A-CK for Custom/Custom Trail Boss
3000K amber mode. Lasfit T-series LED bulbs are specially made to replace OEM halogen turn signal lights. Erorr free, no hyper flash. Besides, intelligent temperature control and play and play installation also designed for 2019-2021 Chevy Silverado 1500.
Please note that there are many trims available for the 2019-2021 Silverado, and it is important to select the appropriate LED bulb based on the trim. This information is already indicated on the product page, so please pay attention when making a purchase.
Back Up Light: T-T15(white)
3000LM/set, bright white or brilliant red. CANBUS support for error-free. Built-in intelligent temperature control system. 100% plug-and-play installation can be completed in about 5 minutes on most vehicles.
License Plate Light: L-T10(white)
800LM/set, 6000K pure white. 3 high-power 3030 SMD LED chips, top and one on each side, much brighter than OEM halogen bulbs. Non-polarity design, no need any modification, just for plug and play installation.
Real Review from Lasfit customers
Huge thanks to them for sharing their experience with great pictures!
Case1:
2021 Silverado Custom: Had a great experience with customer service. Product is outstanding and highly recommend.——Daniel Cervantes
Case2:
LED REVERSE LIGHTS: was running some LED reverse lights from eBay that I thought were bright, but once I received these LasFit Reverse Lights, I was amazed! Super bright, brighter than any light on the market. I would definitely recommend! 10/10! Great quality!
Case3:
2021 Chevrolet Silverado 1500: Great lights. Way better than stock Halogens. 100% recommend.Really give the truck a whole new look.——E.P.
LASFIT
Nov 9, 2023 7:32 PM
LASFIT
Sep 5, 2023 9:30 PM
LASFIT
2014 - 2018 (GMT-K2)
Aug 30, 2023 8:28 PM
Ozlhuvuadojo
2007 - 2013 (GMT900)
Oct 11, 2022 4:40 AM
