why don't it fire
When you are testing 2,4,6,8 you are using a different ground area,I believe that is your issue. It is also possible that the routing of the plug has caused them to burn. try switching out the wires for new ones. Good luck.
1993 gms k1500 5.7 timing is correct, wires are correct, fire in all wires, blue fire from coil, all fuses are good, 2 grounds on the motor. all sensors are new, battery is new, tbi is rebuilt and both spray. this is a complete rebuild from bottom to top. the code reader pulled no codes. The truck did start after rebuild, it ran for about 20 min. but now it rotates and fires and it tries, but it just won't start. So I threw money at it and replaced cap, rotor, wires, coil and plugs, and ign. module. It does have a deep back fire, but not a loud backfire like 180 out. I checked timing again and it's still dead on. I am really open to suggestion.
Okay,
It's really an art to adjust new 'empty' lifters. Now that they are full of oil, just betcha that they are too darned tight and they are holding the valves open.
Back the right bank lifters off a half a turn and see if it starts and runs. If so, get 'er warmed up good and re-adjust all.
Allan
Allan
Okay,
Allan
Allan
