Wind whistling noise at higher speeds?
Old Jan 6, 2012 | 2:17 PM
goatdriver's Avatar
Default Wind whistling noise at higher speeds?
At 65 and above, I get a loud wind whistling noise, which sounds like it is coming from the passenger side. I have a 2011 Extended Cab. Does anyone experience this, and hopefully, have a solution?
Old Jan 6, 2012 | 4:26 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> goatdriver,
I have checked my resources and see no known wind whistling noise issue on 2011 Silverado vehicles. If you would like, PM me your VIN number, and I may be able to offer additional information.
Have you taken the vehicle in for an inspection for this issue?
I look forward to your reply.
Louis
GM Customer Service
Old Jan 18, 2012 | 9:03 PM
ptfdchief's Avatar
Default Silverado wind whistling noise
I have a 2010 Silverado Crew Cab and also the wind whistling noise at speeds of approximately 58 mph and above. I had a friend track the noise down to behind the rear seats in the area of the cabin pressure vents. Have not taken to dealer yet but will soon to see what can be done.
rmorgan
Sonic (Aveo)
17
May 5, 2015 4:52 PM
Schotello
Nov 14, 2008 5:49 PM
Tatonka
Apr 8, 2008 11:07 AM
razor.rn
Feb 18, 2008 2:03 PM
