Window Switch
Ive seen this thread a couple times but never see the answer to this question.
If my window stops working. (Pas Front) Do not know if its the motor yet i want to try just the switch.. but would it be the drivers side switch or the passenger switch.. neither works.
i couldnt remember if the main switch went out it would sstop the pas. switch to stop. all other 3 window works. just the passenger window does not?
any help would be awesome.
depends where the failure is, the master(drivers front) has circuits for all the windows ran through it if you're just guessing which we are, i'd go with the passenger switch since all others are working
It obviously is at the top of its travel but does the dome lamp dim when you work either switches in the passenger-front-window-up position? How about in the passenger-front-window-down position? It may possibly tell if the motor is getting power in some fashion.
davbell22602
Mar 10, 2010 8:36 PM
