Wiring
Old Apr 12, 2014 | 1:50 PM
hammernanvil1075's Avatar
Default Wiring
I need to run a wire from the battery into the cab for a switch. Where is the best place to go through the firewall.
Old Apr 12, 2014 | 8:57 PM
country_09's Avatar
There's a big rubber grommet on the firewall, by where the steering column goes into the truck. Usually cut a hole in it and run a wire on a wire hanger or snake through till you can see it
Old Apr 12, 2014 | 9:04 PM
After you do this, make sure there is a good seal to keep water out. use some silicone seal if needed.
billhemingway
May 4, 2010 3:53 PM
Shaun_95
Nov 23, 2009 9:56 AM
UlexiteCavalier
Feb 16, 2009 8:56 AM
smalltuck
Jan 24, 2006 11:32 AM
