Wiring harness issue
Old Sep 18, 2020 | 1:02 PM
Zombiebait's Avatar
Default Wiring harness issue
I need to replace a wiring harness on my 2005 silverado LS 1500 4WD. I dont know what it is called so I'm having trouble finding a replacement. It goes from the under hood fuse box to the under dash fuse box and a few other things. Before you ask why, just know that the previous owner tried to install an amp and drilled through the firewall and the wiring harness. Now I have a random shorts and grounds on my 4WD selector as well as other systems. Any ideas on how to find a new one would be helpful.
Old Sep 18, 2020 | 2:45 PM
You can try the junk yards or try to repair the harness that is there.
Old Sep 18, 2020 | 11:09 PM
I remember someone on this forum posting that they had done just that ... drilled through the harness. Maybe they sold the vehicle to you :P
Anyway, I would pull apart the damaged area to see how many wires were actually damaged. If it's not too many , then it may be easier to salvage it.
Old Sep 21, 2020 | 10:48 AM
dtcassist's Avatar
Former Sponsor
It sounds like you are describing a branch of the main body harness. How big is the damaged section like an inch plus diameter or small?
If it is the main body harness, I would do everything possible to try to repair it - even if you have to let an electrical shop handle it. The harness goes everywhere in the truck, meaning you would have to strip everything down to get to all of the connections. And finding a replacement will be very difficult. I can guarantee GM won't have one anymore, and even with junkyards, you would have to have exactly the same option and setup for everything as your truck. Otherwise the replacement harness won't have the same connections or correct sizes.
Kogs
Aug 3, 2018 9:10 PM
lsufan88
Jan 29, 2012 2:17 AM
djgj74
Aug 28, 2010 5:56 PM
lugnuts
Dec 25, 2008 9:20 PM
