Won't idle right
Old Aug 2, 2007 | 11:05 AM
Diesel Dan's Avatar
Default Won't idle right
I have a 1988 crew cab dually with a 454 TBI motor. I recently put on new headers, while I was doing that I put in new spark plugs, wires, cap, and rotor. I started it up and was running but it won't idle it has a loping sound to it and then it will stall out. So i replaces the O2 sensor and took it for a drive and it still will not idle it seems to have pwer but something is not right. Any ideas would be great thanks Diesel Dan
Old Aug 2, 2007 | 1:04 PM
RonH's Avatar
Default RE: Won't idle right
Check to make sure you got the spark plug wires to the right plugs.
Old Aug 2, 2007 | 7:19 PM
kcb37's Avatar
Make sure your cap is tight and that the distributor clamp is holding tight. That may be something like an airflow sensor too. Make sure your throttle body is clean too.
02Z71silverado
10
Jan 24, 2016 1:11 PM
thompjs
Jul 6, 2015 11:18 AM
Tim Knepper
Camaro
Mar 22, 2012 8:15 AM
1LooseLugNut
Aug 15, 2010 6:18 PM
